sanostol Posted August 30, 2006 Share Posted August 30, 2006 Hi, which player version do You use to play this monster file. I'm using 7.1 and it dies when it comes to shading and texturing. does it work with v6.5? Quicktime 7 is really far away from stable, but You can't watch any trailers anymore if You don't use it. Other than that the DVD is great!! martin Quote Link to comment Share on other sites More sharing options...
zoki Posted August 30, 2006 Share Posted August 30, 2006 hi write them back I had the same problem they will fix it very fast! z Quote Link to comment Share on other sites More sharing options...
wavesmack Posted August 30, 2006 Share Posted August 30, 2006 We fixed the problem by breaking the video into two halves. It isnt the movies iteself that was causing the problem. Its the burn of the movie that goes wild. So if you havent tried breaking it in half with quicktime pro, email me for the proper version. This was only a problem for the first set of orders. by now most of them should have had new dvd's sent already. -c Hi, which player version do You use to play this monster file. I'm using 7.1 and it dies when it comes to shading and texturing. does it work with v6.5? Quicktime 7 is really far away from stable, but You can't watch any trailers anymore if You don't use it. Other than that the DVD is great!! martin Quote Link to comment Share on other sites More sharing options...
jjstanley Posted August 30, 2006 Share Posted August 30, 2006 I had a lot of problems getting mine to work. What I finally found was to copy it to my hardd rive and play with VLC was the only way to make it work. Quote Link to comment Share on other sites More sharing options...
