3__ Posted August 30, 2006 Share Posted August 30, 2006 Having some trouble with chread; tried the following with no luck: chread -o $TSTART "obj/cam1/tx" "obj/cam1/ty" "obj/cam1/tz" "obj/cam1/rx" "obj/cam1/ry" "obj/cam1/rz" "obj/cam1/focal" 'C:/temp/maxcamtest.chan' This made keys in tx but they had no value. The other channels were ignored. Is this the correct syntax for writing to multiple channels? Also how to I make the channels 'raw' in the first place? the help page doesn't elaborate... In the above case I just typed in a random string. thanks, -cpb Quote Link to comment Share on other sites More sharing options...
ptakun Posted September 6, 2006 Share Posted September 6, 2006 Yo!! Can You show the file 'C:/temp/maxcamtest.chan' ?? Cheers!! Quote Link to comment Share on other sites More sharing options...
3__ Posted September 8, 2006 Author Share Posted September 8, 2006 yep see attached... -cpb maxcamtest.zip Quote Link to comment Share on other sites More sharing options...
ptakun Posted September 8, 2006 Share Posted September 8, 2006 yep see attached...-cpb Hi Every channel in file maxcamtest.chan must be separated with tab. Just check: Channel editor/Animate/Load-Save Channels Cheers! Quote Link to comment Share on other sites More sharing options...
3__ Posted September 11, 2006 Author Share Posted September 11, 2006 Now when I try to read the attached chan file (tab separated vector values) with the following command I get a segmentation fault with V8.1.655. chread -f 1 78 "obj/cam1/tx" "obj/cam1/ty" "obj/cam1/tz" "obj/cam1/rx" "obj/cam1/ry" "obj/cam1/rz" "obj/cam1/focal" 'C:/temp/maxcamtest.chan' When saving channels via channel editor and loading back in using chread there are no problems... -cpb maxcamtest.zip Quote Link to comment Share on other sites More sharing options...
ptakun Posted September 11, 2006 Share Posted September 11, 2006 If You use: chread "obj/cam1/tx" "obj/cam1/ty" "obj/cam1/tz" "obj/cam1/rx" "obj/cam1/ry" "obj/cam1/rz" "obj/cam1/focal" then every channel data must be separated in one line. Like this: tx ty tz rx ry rz focus next frame... Quote Link to comment Share on other sites More sharing options...
