wrangle - string reference in vex from spare parameter
hughspeers
Hi there, this is probably way simple and a dumb question  but....
I'm trying to make a tool that will use a string from a spare parameter and use it to reference geometry on a drive.
The point() function works if I type in the value - check . I can make a new attribute and reference the spare parameter- check.
But when I use the string attribute or directly reference using ch('myparameter') from within the point() function I draw a blank.
I suspect its changing the string to float or something in the point() function.
Any help much appreciated :)
Thanks
John
//mycode
s@mystring =  chs(“geo”);
v@Cd = point("mystring",“Cd”,@ptnum);
v@P = point(“mystring”,“P”,@ptnum);
