Wedging Specific Values
The Wedge TOP can handle this... just enable "Target Parameter", point to the attribute you want to vary, and then set the Wedge Type to Value List and type in the values you want. Then write the results out via a ROP Geometry TOP. The Wedge TOP example file at the bottom of the help card is a pretty good explanation.
