transform matrix attribute not working inside instance node
16 minutes ago, anim said:
Instance SOP?
it should, since instance SOP is using Copy SOP (even though the old one), so both 3@transform as well as 4@transform should apply transforms to copied geo, and it does in my tests
Use object-level instance then apply the attribute to the point inside the instance node
