nailedit Posted March 21, 2020 Share Posted March 21, 2020 Hi I'm trying to add up deformation from 2 animated objects (or rather, same object with 2 animations, so the topology is the same). I've been reading up on this but wasn't able to find anything. I was wondering wether anyone had an idea how would you go about this? My only guess is matricies, but I haven't used them in quite a while and would probably start learning over, so to avoid unnecessary time sink I wanted to ask wether someone did this with matricies succesfully? Hopefully its pretty clear what I'm trying to achieve, but if not I found this post which describes the same problem and has example file with the issue in question. Quote Link to comment Share on other sites More sharing options...
