monomind Posted March 25, 2020 Share Posted March 25, 2020 I'm using a "file" node to load files, but because of my weird naming of the sequence, I've read the file sequence using a custom VEX expression. I have a slider, and depending on the slider, numbers (in the middle of the file name, such as File_0001_reflections_dark.exr) update. When I drag the slider, I can see different frames being loaded. My initial idea was to connect this to a ROP node and export every frame using $F - however when I type in $F for my slider, I get a big cross instead of the image itself. It does not error, it just looks like it's not "loading" for some reason. I believe this is because of some performance option? If there is a setting to force updates, I'd love to know! Or if I'm missing something very basic please enlighten me! Quote Link to comment Share on other sites More sharing options...
monomind Posted March 25, 2020 Author Share Posted March 25, 2020 Looks like the image data and resolution is correct, and there, it's only the frame that "looks" missing. Quote Link to comment Share on other sites More sharing options...
fsimerey Posted March 25, 2020 Share Posted March 25, 2020 (edited) Try with this: File_$F4_reflections_dark.exr or File_`$F4`_reflections_dark.exr Edited March 25, 2020 by fsimerey Quote Link to comment Share on other sites More sharing options...
