uniformly scaling in specific axis
not sure it's doing what you  think it's doing
but if you just want non-uniform scale (which is what uniform scale in certain axis sounds like) then use Transform SOP and scale just in X and Z for example
Edited by anim
Hi @anim
I don't know what to think anymore :D
To be clear. I am trying to make a simple table with 6 legs. I am placing the legs by "shrinking" the underside of the table and using the side points to copy the legs on to.
The solution I posted before does not work, because I have two points in the middle of the table that will scale wrong, so I made a pretty ugly solution with a fit function. It seems to be a very simple task to do, so I am sure that there is a more elegant way?
Here's an example of my ugly solution.
table_example.hip
Edited by An_pi
