Avoid Windows Sleepmode with running hbatch
maybe anyone knows an easy solution for this. I usually use the sleep mode for my machine if I do not use it for some time. Unfortunately it goes to sleep mode even if a hbatch process is running on all cores. I now turned the sleep mode off, but does anyone know a simple solution for this problem? For Windows7 I once used a standalone tool where you can select a process and it keeps Windows awake as long as this process is running. Is this still necessary? Or are there any Windows10 built in options? I even do not understand why it goes to sleep at all if it is working.
