sneaky Posted April 6, 2020 Share Posted April 6, 2020 Hey, I am trying to reproduce this kind of structure that we can see on this website : http://acme-experience.com/ (under the menu in the bottom left corner). So far I manage to create polylines between points of a grid (pic. 2). But I think this is not the way to go for this effect. Because my polylines have always the same size and they don't seems to come from the center to the outer as much as in the example. I am not so far though but if u have any idea on how I could improve it let me know I am stuck since a day on it... You can find my project file linked if it is helpful. Thank you for reading, And as always take care drawRectLines.hip Quote Link to comment Share on other sites More sharing options...
Librarian Posted April 6, 2020 Share Posted April 6, 2020 (edited) node = hou.pwd() geo = node.geometry() # Create Variables. iterations = node.parm("iterations").eval() originx = float(node.parm("originx").eval()) originy = float(node.parm("originy").eval()) point1x = float(node.parm("point1x").eval()) point1y = float(node.parm("point1y").eval()) point2x = float(node.parm("point2x").eval()) point2y = float(node.parm("point2y").eval()) # Import math for the hilbert function import sys, math # Create the class that does the heavy lifting for the Hilbert Curve class Hilbert: # Recieve the variables from Hilbertclass def __init__(self, x0, y0, xi, xj, yi, yj, n): # Send variables to hilbert function for math to be done self.hilbert(x0, y0, xi, xj, yi, yj, n) def hilbert(self, x0, y0, xi, xj, yi, yj, n): if n <= 0: X = x0 + (xi + yi)/2 Y = y0 + (xj + yj)/2 point = [X, Y, 0] # Send data to data, which whill pass it back to Hilbertclass self.data(point) else: # The fancy math. Thank you Malcolm Kesson! self.hilbert(x0, y0, yi/2, yj/2, xi/2, xj/2, n - 1) self.hilbert(x0 + xi/2, y0 + xj/2, xi/2, xj/2, yi/2, yj/2, n - 1) self.hilbert(x0 + xi/2 + yi/2, y0 + xj/2 + yj/2, xi/2, xj/2, yi/2, yj/2, n - 1) self.hilbert(x0 + xi/2 + yi, y0 + xj/2 + yj, -yi/2,-yj/2,-xi/2,-xj/2, n - 1) def data(self, point): # Pass data back to Hilbertclass pass # This is the class that creates the points for the Hilbert Curve class Hilbertclass(Hilbert): def __init__(self, x0, y0, xi, xj, yi, yj, n): # Give the input data to the base class Hilbert.__init__(self, x0, y0, xi, xj, yi, yj, n) def data(self, point): # Create the point curve = geo.createPoint() # Set the position of the point curve.setPosition(point) # Add this newly set point to the polygon poly.addVertex(curve) # Create a Polygon to hold the vertex data poly = geo.createPolygon() # Set the polygon to be open so it acts like a line polygon = poly.setIsClosed(False) # Call Hilbertclass to begin all the procedures Hilbertclass(originx,originy, point1x,point1y,point2x,point2y, iterations) plus you have L-system that you can have more fun tutorials.cgrecord.net/2016/12/vex-in-houdini-space-filling-curves.html Edited April 6, 2020 by Librarian 1 Quote Link to comment Share on other sites More sharing options...
Librarian Posted April 6, 2020 Share Posted April 6, 2020 Or just use this and have endless fun...but you must warm up the chair to get desire effect ...but when you have at the end oj oj Hope it Helps OdforceUI.hipnc 1 Quote Link to comment Share on other sites More sharing options...
sneaky Posted April 6, 2020 Author Share Posted April 6, 2020 Hey thank you very much for your reply, This look really cool, however I have to say this is too advanced stuff for me. But I will surely try to dive deeper on it once in a while. Maybe I am just trying to do something too complicated for my current skills... Thank you again for sharing this which look tremendous! 1 Quote Link to comment Share on other sites More sharing options...
