How To Invert $life Values?
chrisedu
A more general (and more expensive but more flexible) solution is to use the fit() or one if it's variants fit01() fit11() and fit10().
e.g.: fit($LIFE, 0, 1, 1, 0)
remaps $LIFE to the complement. In this case, yes 1-$LIFE is more efficient but remapping to another range requires offsets and multipliers.
A simpler version:
fit01($LIFE, 1, 0)
where you know $LIFE will be between 0 and 1 hence the name fit01.
You can remap the range to whatever you want.
fit01($LIFE, 0.8, -0.2) will remap $LIFE going from 0 - 1 to 0.8 - -0.2 and so on....
Hope this is helpful. Perhaps too much information.
  • 4 weeks later...
A simpler version:
fit01($LIFE, 1, 0)
try using the Age POP and $AGE instead, unless you like getting into expressions ;)
