The xyzdist function does not work well
you are copying N from the points so it'll not be what you think
also in this line:
vector near_pos2 = primuv(2, "p", near_prim, near_uv) ;
the "p" should be capital "P"
vector near_pos2 = primuv(2, "P", near_prim, near_uv) ;
and alternatively you can use Point Deform SOP which will work straight away, plus it will offer you ability to smooth out the deformation a bit and also it will work in case some points are outside of rest geo
solver_xyz_dist_fix.hipnc
also in this line:
Thank you so much
