tmac2k7 Posted April 12, 2020 Share Posted April 12, 2020 (edited) Having difficulty with the flow direction of this roof curve normals. I know there is an easy fix but its just tearing me apart lisa. Simply put it, I want the roof edge tiles to flow down the roof edges. Roof_CurveNormalsError.hip Edited April 12, 2020 by tmac2k7 Quote Link to comment Share on other sites More sharing options...
Noobini Posted April 12, 2020 Share Posted April 12, 2020 the sorting by Y actually does stuff all, test it on a single and you'll see. You have to actually reverse the line to make a difference I've also added Axisalign after your transform8 to make things quicker to line up...most likely you'd play around with Z axis vu_Roof_CurveNormalsFix.hiplc 1 Quote Link to comment Share on other sites More sharing options...
tmac2k7 Posted April 13, 2020 Author Share Posted April 13, 2020 Thank you so much for quick response. I knew it was a simple fix but I did not know how to do it, "I did Not"! Quote Link to comment Share on other sites More sharing options...
