reduce the file size of alembic cache
I just create a fluid simulation and cache out the fluid surface. Now I want to export out the whole sequence as abc. file, but the file size is too big. One frame of the fluid surface cache is 132,140 kB, but when it cache 1 frame of abc. it's 316,627 kB. Is there a way to reduce the file size? I plan to import the abc. into Maya.
  • 9 months later...
