Trying to compile block an intersection analysis
Hi there!
I'm trying to implement a compile block in this intersection analysis bellow (see example attached)
At the left you will find a single thread setup and at right the multithread version.
I'm trying to find a way to make the multicore setup to work.
I've already seen the compile SOPs masterclass, but I couldn't find an answer. The STOP CONDITION seems to be unsupported until the date of the masterclass, but even disablying it, still not working.
https://vimeo.com/222881605
I'm doing a project with a lot of this kind of work and I'd like to improve the processing time.
Does anyone know what I'm doing wrong?
Thanks!
Cheers!
Marco
intersection_analysis_01.hiplc
  • 2 weeks later...
Feedback loop can't be compiled because each process needs all process before itself.
I like this algorithm for avoid intersection, but we need pre-clustering of geometries by using low cost geometry representation like bbox or shperes for multi threding.
