rochre Posted April 22, 2020 Share Posted April 22, 2020 Learning Pyro and I have one sphere that is emitting fuel. As second sphere is emitting heat to ignite the fuel and then moving out of range, it's basically the igniter. Problem is that the fuel begins to burn and then the fire dies. I've tried increasing the fuel scale, reducing fuel inefficiency and other setting but no luck. I can't get the fuel to burn on its own. Any parameters I should be looking at? Thanks. Quote Link to comment Share on other sites More sharing options...
