bullet + flock = trembling HELP!!
dyei nightmare
whassap  dudes,  i come here with this new issue,   i have this bullet setup where i have some noise, and a flock system,  the thing is, i have here a system where im changing all the time the rotation with this vex expression:
matrix3 mtx = dihedral({0,0,1}, normalize(@v));
setprimintrinsic(0, "transform", @ptnum, mtx);
this transforms each packed particle so it always keeps the z axis in front,   and this is cool, but the problem is that some particles are trembling while they are rotating,   is like a small flickering in some particles,  and i want it to interpolate rotations in a smoother way,
maybe flock force is interfering with the rotations?   how can this be fixxed?  i want a smooth rotation interpolation.
 the trembling is subtle, but it is there, when particles are rotating.
HEEEEELLLLLLPPPPPP!!
flock_odforce.hip
Edited by dyei nightmare
You want to be finding the matrix that will transform your local Z to point to the direction of movement, not world Z. Then multiply your local matrix against that new matrix to apply the rotation.
matrix3 current_xform = primintrinsic(0, "transform", @ptnum);
vector local_Z = current_xform * {0,0,1};
matrix3 delta = dihedral(local_Z, normalize(v@v));
matrix3 out = current_xform * delta; // might need to reverse these terms
setprimintrinsic(0, "transform", @ptnum, out);
This will work more reliably when you have more gradual velocity changes, since dihedral is inherently a bit of a guess.
Just saw Farmfield's post... he's right that this can potentially be smoother when you're applying as a force. In that case, what you'd want to do is take that "delta" computed above and convert it to an axis/angle quaternion (a vector3), then add the result to v@torque:
vector torque = qconvert(delta); // converts to an "axis/angle" quaternion
v@torque += (torque * f@mass); // remove mass term if you want mass to matter here
Edited by toadstorm
typo
thanks for the help, ill try it and coment my result haha
seems like qconvert only acepts matrix 4 to convert to a matrix 3,  do you think it is necesary?
https://www.sidefx.com/docs/houdini/vex/functions/qconvert.html
on the other hand,  looks like applying local z  to a force just spins each particle faster each frame
45 minutes ago, toadstorm said:
My bad, try this:
vector4 delta = dihedral(local_Z, normalize(v@v));
thanks a lot,  it just keeps spining around,  think the local z axis request causes this,   letme see
Okay, try something like this file.
Here I'm setting v@targetw and f@spinresist, which is how POP Drag Spin works. It's setting a goal angular velocity rather than applying a direct force, which is a bit easier to control. However, this doesn't solve all of the jittering... part of the problem here is that your objects are colliding with each other while they try to maintain a specific orientation, and this can cause jittering. It's not quite as severe as in the file you posted, though.
flock_odforce_toadstorm.hiplc
  • Thanks 1
thanks a lot!!  basically you fixed it!
another little thing,  how could you keep the up vector point to global 0,1, 0 ?   much like  a fish crowd?
In that case, instead of using dihedral to compute the matrix that would rotate your instances to face the velocity vector, you need to construct a new "goal" matrix comprised of your velocity vector and your global up, and then compute the difference between your current transform and your "goal" transform before applying it as torque like in the earlier file.
matrix3 goal_xform = maketransform(normalize(v@v), chv("up"));
matrix3 delta_xform = invert(current_xform) * goal_xform;
vector4 qdelta = quaternion(delta_xform);
You can then just set your "up" parameter to whatever you want.
  • Thanks 2
YEAH!  IT WORKED!  :lol::lol: :lol::lol: :lol::lol:
thanks!!!
YOU ARE THE MAN
