3dfreelancer Posted April 25, 2020 Share Posted April 25, 2020 (edited) Hi there a very frustrated noob here. I recently moved from another 3d aplication, and Im a newby in Houdini. I did a pyro simulation ( following a tutorial ) and I wanted to do " Save to disk in background " to cache sim ( in geo Pyro Import Node / Dop Import Pyrofields ) but I constantly get message " Cannot perform background render with unsaved changes.Save your file before proceeding." I saved pretty everything I know; project path, sim path ( also tryed ctrl + s) etc. I also checked title in file path so there's no empty space between letters. What am I doing wrong. What else do I need to save, or Im doing it wrong way ? I could not find step by step anywhere explained anything related to " save to disk in background " issue with this message. Could someone pls explain step by step ( if it does not take too much time ) how it should be done so I can check if I did something wrong. I'd very apreciate it and it would help me a lot. Ty very much in advance. Edited April 25, 2020 by 3dfreelancer Quote Link to comment Share on other sites More sharing options...
EricEDFilms Posted May 20, 2020 Share Posted May 20, 2020 I'm having the exact same issue. Bump! Quote Link to comment Share on other sites More sharing options...
Marc Posted May 21, 2020 Share Posted May 21, 2020 you need to save the hipfile Quote Link to comment Share on other sites More sharing options...
3dfreelancer Posted May 21, 2020 Author Share Posted May 21, 2020 (edited) 12 minutes ago, Marc said: you need to save the hipfile I did save, in set in DOP I/O import_pyrofields output, also CTRL + S, and from meni FILE - SAVE AS - name.hip again nothing...cannot perform background render. Edited May 21, 2020 by 3dfreelancer Quote Link to comment Share on other sites More sharing options...
andehpandeh Posted November 22, 2021 Share Posted November 22, 2021 same, I saved my file before trying to save in background, still the same error! Quote Link to comment Share on other sites More sharing options...
