thomas67 Posted April 28, 2020 Share Posted April 28, 2020 (edited) I'm not sure if I do it wrong or if this is a limitation of the Gas Upres. I want to upres my colored smoke. Unfortionately it creates an extremly ugly thin film around my smoke. My problem is very easy to reproduce, just use colored smoke shelve tool preset and then "Upres Container" shelve (don't forget ti add Cd and Alpha in advect_density1 inside Gas Upres node). Is there a fix? Thanks ! Edited May 3, 2020 by thomas67 Quote Link to comment Share on other sites More sharing options...
bunker Posted April 29, 2020 Share Posted April 29, 2020 I wouldn't expect the viewport to be 100% accurate, did you try a render? also maybe have a look at this thread: Quote Link to comment Share on other sites More sharing options...
thomas67 Posted April 29, 2020 Author Share Posted April 29, 2020 Hey bunker, yes it's also visible in render (actually even worse ) I followed your workflow, also used your trick with cdl, unfortionately it didn't solve the problem Quote Link to comment Share on other sites More sharing options...
bunker Posted April 29, 2020 Share Posted April 29, 2020 maybe you could include a .hip file? Quote Link to comment Share on other sites More sharing options...
thomas67 Posted April 29, 2020 Author Share Posted April 29, 2020 Colored_Smoke_Upres_Problem.hip Quote Link to comment Share on other sites More sharing options...
thomas67 Posted May 2, 2020 Author Share Posted May 2, 2020 I guess there's no fix? =/ Quote Link to comment Share on other sites More sharing options...
bunker Posted May 3, 2020 Share Posted May 3, 2020 if you look inside the lowres smoke solver you'll see that Cd is handled separately, not just advecting Cd so the fix is to copy those nodes inside your upres solver. Colored_Smoke_Upres_Problem.hiplc Quote Link to comment Share on other sites More sharing options...
thomas67 Posted May 3, 2020 Author Share Posted May 3, 2020 Amazing. Thank you so much ! Quote Link to comment Share on other sites More sharing options...
