Mohanad Posted April 28, 2020 Share Posted April 28, 2020 I'm trying to partially tear a ground object (flat box) in vellum and so far i've managed to achieve the desired effect by using boolean subtracting a curve, except that now it appears hollow without the internal "bridge" between the border edges. Polybridge works manually for the most part but I would rather achieve this in a more procedural manner. I have attached an image and a hip file. vellum tearing.hipnc Quote Link to comment Share on other sites More sharing options...
Noobini Posted April 29, 2020 Share Posted April 29, 2020 now why would you go and make life harder for yourself ? here: ( I left a 2nd way to get thickness in there...but the 1st is best i reckon) vu_vellum tearing.hiplc Quote Link to comment Share on other sites More sharing options...
Mohanad Posted April 29, 2020 Author Share Posted April 29, 2020 7 hours ago, Noobini said: now why would you go and make life harder for yourself ? It's a lifestyle Thanks for the tip, I didn't know you could add thickness in post! However I probably wasn't clear enough, the grid with the polyextrude was a placeholder for geometry that already comes with thickness and I need to cut it procedurally. Here's the same file with a geometry that perhaps better represents my problem vu_vellum tearing01.hiplc Quote Link to comment Share on other sites More sharing options...
