Transform RBD Pieces
ai88
6 minutes ago, Noobini said:
I see no 'blocky' problem at all, 18.0.416
I deleted that big chunk in Dop by speed expression. I got point cache and did transform pieces. I can still see in 17.5.
oh now I see the 'blob'...nothing to do with cache or 17, in H18 i can see it, because of your delete I think, since the number of points no longer match up ? Like if you delete point 500 in DOP...what's going to control block 500 in transform pieces ?
So what I did was instead of removepoint I simply said if speed > MaxSpeed
set speed = MaxSpeed
How can I write that expression?
f@speed = length(@v);
if (@speed > ch("MaxSpeed") && @Frame < 10){
    set(@speed = ("MaxSpeed");
just if (@speed > ch("MaxSpeed") && @Frame < 10) @speed = ch("MaxSpeed");
(i was just speaking to you in Engrish, that's all)
