Whatsinaname Posted May 1, 2020 Share Posted May 1, 2020 I know you can somehow display the path to the OTL definition on top of the parameter menu and also use that to swap OTL definitions. The problem is, the option to show this is hidden somewhere and I cannot find it, so any help would be very much appreciated. Quote Link to comment Share on other sites More sharing options...
vicvvsh Posted May 1, 2020 Share Posted May 1, 2020 On 5/1/2020 at 10:46 AM, Whatsinaname said: I know you can somehow display the path to the OTL definition on top of the parameter menu and also use that to swap OTL definitions. The problem is, the option to show this is hidden somewhere and I cannot find it, so any help would be very much appreciated. Expand Hi, go to menu Assets, then Asset Manager (or RMB on an asset in Network View -> Show in Asset Manager), tab Configuration, drop down menu "Asset Bar" 1 Quote Link to comment Share on other sites More sharing options...
