Omni Posted May 2, 2020 Share Posted May 2, 2020 Hi. I'm currently unable to obtain motion blur on render using Houdini and HtoA for a destruction sequence in a shot. This is a standard rbd setup using a packed .bgeo.sc geometry file. I am transforming this geo using the bullet simulation points transform attributes with the "Transform Pieces" SOP. It allows me to have @v attribute on my packed geo but Arnold doesn't seem to pick it up even though motion blur is enabled on my ROP. It seem to be due to the fact that my geo is packed since upacking it and transfering @v from the packed geo to the unpacked geo allows motion blur to work. This is a very noticeable performance hinder at render time since the geo is heavy and unpacking adds useless overhead. I was wondering, what is the proper "clean" workflow to render rbd simulation sequences from Houdini with Arnold? Would creating a .ass archive solves the problem? If so, do i have to export each frame, unpacked, to the archive? If so, it seems like a waste of hard drive space and time... Hoping someone can shed some light on this. Quote Link to comment Share on other sites More sharing options...
schwungsau Posted May 13, 2020 Share Posted May 13, 2020 (edited) external renderers does not support packed bgeo. otherwise, if you render on a renderfarm, it would take 1 additional Houdini licence per machine. (loading a bgeo file format will draw one licence). you need to use fast instance points and on the points, create a sting attr, which points to an alembic or an ass file. Edited May 13, 2020 by schwungsau Quote Link to comment Share on other sites More sharing options...
