how to get particle points angle difference between previous frame
zzlettle
hi
 just learn houdini particle.
i am a beginner
in this project i use particles points then use copy to points node , boxs to make up model.
like this picture
however the problem is
i find some box jitter very unacceptable
so i Calculate the points distance between previous frame in solver node
if the distance less than 0.05,then the point do not move
this way make the points jitter less
however i need calculate the angle distance between previous frame also
but
i do not know how to calculate the rotation difference
let`s say ,if the rotation difference less then 0.1,then the point do not rotate.
bellow is the project file
point_jitter.hip
thanks for your help
what you can do is to create a 3x3 transform matrix that will tell houdini what orientation has your instance from your normal
vector y = v@N;
vector x = normalize(cross(y, set(0, 1, 0)));
vector z = normalize(cross(x, y));
3@transform = set(x, y, z);
Houdini has priorities for points orientation from higher to lower priority it is :
matrix3 transform
vector4 orient
and then a combinaison of vectors like : v@N / up or v@v / up
the main problem i see is points jittering not really points orientation
i attached you a file, hope it is what you intended
point_jitter.hiplc
