Nicholas Ralabate Posted May 7, 2020 Share Posted May 7, 2020 I can dive into the light and see the hlight OP, and I see the relevant SOPs but I don't see where the light shader is wired up. I can also expose the hidden render parameter for light shader but that just gives me a blank field. How does a light know which light shader to use? Also, are there any differences between light shaders between H8/H9 approaches? I am mostly concerned with PBR backend. I see in $HH/Vex/Light there are some light shaders assigning to the Cl variable but I'm not sure if that is specific to raytracing backend or if it applies to both raytracing backend and PBR backend. Quote Link to comment Share on other sites More sharing options...
anim Posted May 8, 2020 Share Posted May 8, 2020 I think SOHO assigns the shader based on the renderer and the light properties, that allows Light Object to be the same and still support multiple renderers and shaders this is done using SOHO light wranglers, for example this one is for standard light for Mantra, there is more for other lights like env, indirect, ... $HFS/houdini/soho/python2.7/wranglers/HoudiniLightIFD.py Quote Link to comment Share on other sites More sharing options...
Nicholas Ralabate Posted May 8, 2020 Author Share Posted May 8, 2020 Thank you, thats's great info! Quote Link to comment Share on other sites More sharing options...
