anicg Posted May 9, 2020 Share Posted May 9, 2020 (edited) Why does the attribute noise on velocity cause the whole simulation to go in one specific direction? and I'm not even able to change the direction, it's always the same. Here are screen shots with the attribnoise enabled, then disabled and the pyro solver settings. How do I tell that attrib noise not to go in that direction? I've changed its settings but it doesn't change direction. Even if I change the source geometry behind the smoke, even if I rotate the source, the direction stays the same. Edited May 9, 2020 by anicg Quote Link to comment Share on other sites More sharing options...
