Shadow Pass
Hey All
I've got an issue with shadows
I have my scene with all my saders nicely laid out in Shopnets in all
the places I need them in different objects and whatnot.
However I tried the trick from the renderpass workflow tut at sesi,
and it would'nt work until I deleted all my shopnets. I also tried the opparm
prerender script thing but also to no avail. This seems to be a bug to me.
It very well could be scene specific. However my question is this.
What is your usual workflow for doing a shadow pass, without deep rasters or EXR.
any suggestions would be great.
Thanks much
-Lyn-
Yep Thats what the renderpass workflow tut says to do.
I loved the idea except that it did'nt work. I really may have something scene specific.
I have managed to get my shadowpass but at the expence of getg rid of my shopnets.
Not the prefered workflow. Shadow pass is so basic and rudimentry I am suprised by
what I am seeing here. It my be that I am thick, but I think I should be able to quickly and eaisly
overide the shading on a ROP by adding a shader to the entire pass.
I must say I can't understand your problem. Could you attach some basic hip file example.
I work a lot with passes all the time also in case of shadows.
By the way: takes can be tricky. For example it's hard to manage in which take you modify your settings. It's easy to derivatate subversion from previous subversion not from a main take. This way you loose control over your scene. If you miss that point you are in trouble. Just one example of my problems with takes... ;)
cheers,
SY.
