lynbo Posted September 21, 2006 Share Posted September 21, 2006 Hey All I've got an issue with shadows I have my scene with all my saders nicely laid out in Shopnets in all the places I need them in different objects and whatnot. However I tried the trick from the renderpass workflow tut at sesi, and it would'nt work until I deleted all my shopnets. I also tried the opparm prerender script thing but also to no avail. This seems to be a bug to me. It very well could be scene specific. However my question is this. What is your usual workflow for doing a shadow pass, without deep rasters or EXR. any suggestions would be great. Thanks much -Lyn- Quote Link to comment Share on other sites More sharing options...
sibarrick Posted September 21, 2006 Share Posted September 21, 2006 Have you tried using takes? That would be the easiest way I would have thought. Quote Link to comment Share on other sites More sharing options...
lynbo Posted September 21, 2006 Author Share Posted September 21, 2006 Yep Thats what the renderpass workflow tut says to do. I loved the idea except that it did'nt work. I really may have something scene specific. I have managed to get my shadowpass but at the expence of getg rid of my shopnets. Not the prefered workflow. Shadow pass is so basic and rudimentry I am suprised by what I am seeing here. It my be that I am thick, but I think I should be able to quickly and eaisly overide the shading on a ROP by adding a shader to the entire pass. Quote Link to comment Share on other sites More sharing options...
symek Posted September 22, 2006 Share Posted September 22, 2006 lynbo said: Yep Thats what the renderpass workflow tut says to do.I loved the idea except that it did'nt work. I really may have something scene specific. I have managed to get my shadowpass but at the expence of getg rid of my shopnets. Not the prefered workflow. Shadow pass is so basic and rudimentry I am suprised by what I am seeing here. It my be that I am thick, but I think I should be able to quickly and eaisly overide the shading on a ROP by adding a shader to the entire pass. I must say I can't understand your problem. Could you attach some basic hip file example. I work a lot with passes all the time also in case of shadows. By the way: takes can be tricky. For example it's hard to manage in which take you modify your settings. It's easy to derivatate subversion from previous subversion not from a main take. This way you loose control over your scene. If you miss that point you are in trouble. Just one example of my problems with takes... cheers, SY. Quote Link to comment Share on other sites More sharing options...
lynbo Posted September 22, 2006 Author Share Posted September 22, 2006 Sure sure I'll post something this weekend as I don't have the file until I get back. I think I have some shopnet somewhere that Houdini does'nt like. When I remove them I get the result I am looking for. kinda strange. Thanks Quote Link to comment Share on other sites More sharing options...
lynbo Posted September 26, 2006 Author Share Posted September 26, 2006 sorry I havent upped a scene yet I'm swamped at work at the moment I'll put something up soon. must make deadline......... Thanks Quote Link to comment Share on other sites More sharing options...
