Help with retiming multiple explosion instances
originalClown
I've scattered 5 explosions to points using a switch node and a foreach loop. The explosion are randomly assigned to point but I need to have them offset at random as well. How would I go about achieving this? The effect I'm going for is flak in a WW1 scene but at the moment all the explosions start at the same time
If you're loading the explosions in as packed disk sequences (option is on the File SOP) then you can set the "index" primitive intrinsic attribute after the Copy operation to choose your offset. For example:
float rand_offset = fit01(rand(@elemnum), 0, 24);
setprimintrinsic(0, "index", @elemnum, floor(rand_offset), "add");
If your flak volumes have more than one primitive, you'd just want to make sure your random offset was the same for all primitives within a single volume (density, vel, temperature, etc)
