logix1390 Posted May 21, 2020 Share Posted May 21, 2020 Hello, I have a test object floating in space . I want to get a ramp that is oriented along the direction its facing no matter what the rotation or position is... I am using a "relative to bound" vop and using the x component to visualize the ramp but it seems like its not actually relative to its bound but to the world. I will attach a screenshot of what I mean. The green arrow is where I want the gradient ramp to face but the red arrow represents what its actually doing ... I will also attach my scene for anyone that wants to take a look. Thanks Ramp_orient.hipnc Quote Link to comment Share on other sites More sharing options...
anim Posted May 21, 2020 Share Posted May 21, 2020 (edited) relbbox is relative to the bounding box of the geometry, it is axis aligned in the object space and since your object doesn't have any transform it's also the same as world space, Transform SOP just moves geometry around, that doesn't affect neither object nor bbox orientation so you can either store your relbbox as an attribute before Transform SOP, then you can use it even after to sample your ramps, or there are more involved methods if necessary depending case by case Ramp_orient_mod.hipncFetching info... Edited May 21, 2020 by anim Quote Link to comment Share on other sites More sharing options...
logix1390 Posted May 21, 2020 Author Share Posted May 21, 2020 @anim Thank you anim, Makes perfect sense. Quote Link to comment Share on other sites More sharing options...
