dyei nightmare Posted May 22, 2020 Share Posted May 22, 2020 is it posible to use FEM target constraints per point? i dont even know if this is deprecated by vellum workflows, but assuming it isnt, im talking about this node. https://www.sidefx.com/docs/houdini/nodes/dop/targetconstraint.html is it posible to define a float values that determines the strenght of the soft target? using "stiffness" as variable doesnt work, and there is just a targetP attribute vector that doesnt help on this and "targetstiffness" is not very acurate, even if you have such a big numbers like 1000000000 it doesnt follow your target very preciselly Quote Link to comment Share on other sites More sharing options...
dyei nightmare Posted May 22, 2020 Author Share Posted May 22, 2020 (edited) the situation is this: basically "targetstiffness" doesnt work at all, even if you have very high value, the only thing that works is fem target constraint, but it doesnt have a per point attribute, is just a boolean, yes or no, and i want to set up a falloff -----------> fem_for_od .hip Edited May 22, 2020 by dyei nightmare Quote Link to comment Share on other sites More sharing options...
dyei nightmare Posted May 22, 2020 Author Share Posted May 22, 2020 (edited) i came up with a solution with target constraint, but it is not the most elegant solution, i would like to find a solution based on a "falloff" attribute like targetstiffness but an acurrate one edit: it looks strange, but dont dont look at is as... "that" ............ fem_for_od2.hip Edited May 22, 2020 by dyei nightmare Quote Link to comment Share on other sites More sharing options...
dyei nightmare Posted May 24, 2020 Author Share Posted May 24, 2020 (edited) im starting to wonder if FEM is obsolete against vellum Edited May 24, 2020 by dyei nightmare nothing Quote Link to comment Share on other sites More sharing options...
