Nickpwalsh Posted May 25, 2020 Share Posted May 25, 2020 Hello, I'm trying to render out separate passes for different objects in my scene. In mantra I would just need to set the correct object and correct forced mattes for each mantra node and then could render them all at once. The force matte option in the redshift rop doesn't seem to work for me. The only way I've found to get mattes to work is to enable them in the redshift properties on the object nodes themselves. I'm hoping there's a way I can batch render these like in Mantra and not have to manually switch the matte options for each pass. Thanks for any help you all can give! Quote Link to comment Share on other sites More sharing options...
Sepu Posted May 25, 2020 Share Posted May 25, 2020 It does work in RS but you have to do an extra step in RS. When you add objects to the force parameter it will enable the `Matte Params From` what I usually do is create a NULL then add the Obj properties in there and enable the Matte and do whatever you need to do there. 2 Quote Link to comment Share on other sites More sharing options...
Nickpwalsh Posted May 25, 2020 Author Share Posted May 25, 2020 Perfect. Thank you! Quote Link to comment Share on other sites More sharing options...
