Redshift totally failed
Hi guy. I had been working with redshift for over a month already and I am in the middle of a proyect. Suddenly when I open the proyect EVERYTHHING failes. There isn´t a single redshift node working:
This is my env:
PATH = "C:/ProgramData/Redshift/bin;$PATH"<font></font>"
HOUDINI_PATH = "C:/ProgramData/Redshift/Plugins/Houdini/17.5.173;&"
It looks like it uninstalled itself somehow. I really don´t know what did I do. It just stopped working from one day to another.
I tried resenting the pc and reinstalling redshift. I hope you can help me. Thank you :(
Edited by pizola
spelling
This is my env:
PATH = "C:/ProgramData/Redshift/bin;$PATH"<font></font>" I am not sure this will work, are you sure this is the right setting? Syntax is wrong, you have unclosed quotation mark and why is this font even here? Maybe check at he redshift forum exact path and edit this. My guess is this line is bothering you.
your env file is messed up...
it should look more like this:
you need to install a prober text editor for windows so try add some fancy formating
try https://atom.io
Edited by schwungsau
