[Solved] Animating Vellum Constraint Attributes in SOP Solver
I'm trying to edit the vellum constraint densitiy inside a DOP network (via an attribute). It looks as if it is working because you can visually see the attribute change, but the simulation is unaffected. Nothing that I try seems to work, is it even possible to do?
I attached my test (sorry it is a little bit messy) and an image of my DOP network. Thanks for reading.
VellumAttributeTransfer.hip
Edited by treebog
fixed
