Crowd Transition Help
Midasssilver
I have am testing the transition between 2 clips in a crowd sim. I only have those 2 clips enabled, and I can see that they have a connection in the Transition Graph. The problem occurs when I queue the transition on a specific frame. Houdini is telling me that the frame Clip B is similar to Clip A is on frame 435, but I know that the frames don't match up until 438, and I can't work around it. If I try and set up a custom transition at 438, the transition is just skipped. Anyone know a way to either force the transition to happen at the appropriate frame, or tell my why Houdini is interpreting my clip incorrectly. Thanks!
