Follyx Posted June 16, 2020 Share Posted June 16, 2020 (edited) an object with voronoichunks. Part of them should set to active for the DOP via a bounding region group. But this kind of grouping just work with pointgroups. How could I select a couple of objects from the chunks via an third object i.e. a box or sphere wich I could move afterward? Elegant would be an approach via pointwrangles: "if it ist inside the region so set it to active..."; so I need the syntax for: "is it inside" [bounding region?], like that. And of yourse the approach with sops... or maybe grouping the points from packed objects and ...or a proxy with placeholder points for the chunks... and, and, and... canot figure it out. Thank you in advance. edit: found one here:is point inside geo? but isnt this example laboirous for my needs? Dont know.. edit: the sop way is solved, was my mistake. But I'am heavily interested in the vex way... Edited June 16, 2020 by Follyx Quote Link to comment Share on other sites More sharing options...
