cybor09 Posted June 17, 2020 Share Posted June 17, 2020 Hi guys! I installed Deadline recently and normally I have a multiple RS Rops where I define the render folder path with a string parameter in a null node. The thing is when I submit the render job to Deadline with the expression that I use for output I'm getting this error: (Syntax error - extra tokens detected in expression (/out/Redshift_ROP_HQ_PMs_DWAA/RS_outputFileNamePrefix)). I 'm defining the folder paths in the null like this: $HIP/render/ And the rest of the expression on the RS Rop is like this: `chs("../RENDER_PATHS/render_folder")`$HIPNAME/$HIPNAME.$AOV.$F3.exr Somebody knows how I have to change the output expression in order to get the render correctly? Here is a screenshot from the expression: Thanks a lot! Quote Link to comment Share on other sites More sharing options...
