Set values of a multiparm folder
Johan
Hi all,
I have a hard time understanding how to programmatically add values to a multiparm folder.
I want to add new items to a multiparm I added on my HDA. I can see all sorts of code for multiparm template groups and how to construct and add them to a node, but hardly any code that actually adds data to the multiparm.
Any pointers are greatly appreciated!
Thanks,
-Johan
Found it, the magic bullet was multiParmInstances and insertMultiParmInstance
    p = obj.parm('folders')
    instances = p.multiParmInstances()
    for i in range(9):
        num_instances = p.evalAsInt()
        p.insertMultiParmInstance(num_instances)
Adds 9 new entries to multiparm block. If you use the naming scheme on the parms like value_# each parm name will increment and you can set values on them like normal.
obj.parm('value_'+str(i)).set(yourval)
Or something similar.
Cheers,
-Johan
  • Thanks 1
