zmfovlr Posted June 19, 2020 Share Posted June 19, 2020 Hi, I did make feather with primitive line And I made uv by UV texture SOP and I use Projection Camera option at point attribute. And than export Alembic But not find uv in Clarisse… I want something like this https://forum.isotropix.com/viewtopic.php?f=5&t=5215 This file is simple exam, it is not feather Thanks prim_line_uv_test_v01.hip Quote Link to comment Share on other sites More sharing options...
abvfx Posted June 19, 2020 Share Posted June 19, 2020 I imagine what you need is Guide Skin Attribute Lookup Sop. First input is the guides/hair and second is the Skin you want to inherit UV's. Quote Link to comment Share on other sites More sharing options...
zmfovlr Posted June 20, 2020 Author Share Posted June 20, 2020 On 2020. 6. 19. at 2:23 PM, abvfx said: I imagine what you need is Guide Skin Attribute Lookup Sop. First input is the guides/hair and second is the Skin you want to inherit UV's. Thanks! I will try this SOP!! Quote Link to comment Share on other sites More sharing options...
