couch Posted June 20, 2020 Share Posted June 20, 2020 I would like to attach a light source to a swinging suspension lamp. Unfortunately I can't figure out a way to transfer the animation of a point representing the end of the cable up to the light on scene level. Light instancing is not possible in this case and I don't want to use light geometry. Please help. Quote Link to comment Share on other sites More sharing options...
anim Posted June 20, 2020 Share Posted June 20, 2020 you can use Rivet Object to get point's position and rotation (if you have correct N and up vectors) as object level transform then just parent your light to the rivet object Quote Link to comment Share on other sites More sharing options...
couch Posted June 21, 2020 Author Share Posted June 21, 2020 Thanks a lot, but how can I get the correct N vector? I used orient along curve to give the point the correct orientation during the animation. However, I fail to apply it to the Normals. No matter what I do, N always aligns itself parallel to one of the scene axes. And so does the light. I’ve attached my scene if you or anybody else want to have a look. The point Lamp_Example.hiplcwhere I would want to attach the lamp can be found in the green colored network box. Quote Link to comment Share on other sites More sharing options...
anim Posted June 21, 2020 Share Posted June 21, 2020 here is a bit simplified setup Lamp_Example_fix.hiplc it should be possible to fully instance your lamps with lights at the end points using instance node, but I don't know the requirements of Arnold for light instancing so for now just rivetting each individually 3 Quote Link to comment Share on other sites More sharing options...
couch Posted June 21, 2020 Author Share Posted June 21, 2020 Thanks for the example anim. It works like a charm and is much cleaner than mine of course. The vex code wasa bit hard to follow, but I could still transfer your techniques into my scene. Arnold does not support light instancing at all, as far as I know. Quote Link to comment Share on other sites More sharing options...
