Can anyone help with render engines conflict crashes in houdini
Hello,
Using Houdini recently has been horrible. It crashes at every turn and feedback from the team is that its the render engines installed i.e redshift & renderman 23.
Can anyone help with how to overcome these issues as its so bad i can hardly do anything with the application. I am almost regretting that i renewed my license.
This is the conf of my houdini env
REDSHIFT_COREDATAPATH = “c:/ProgramData/Redshift”
HOUDINI_DSO_ERROR = 1
PATH = “C:/ProgramData/Redshift/bin;$PATH”
HOUDINI_DSO_ERROR = 2
MOPS=“C:\Users\COUGAR\Documents\MOPS;$PATH”
REDSHIFT_RV_ALWAYSONTOP = 0
REDSHIFT_RV_OPEN_ONLY = 1
PXR_PLUGINPATH_NAME = “$REDSHIFT_COREDATAPATH/Plugins/Solaris/${HOUDINI_VERSION}”
MOPS=“C:\Users\COUGAR\Documents\MOPS;&”
RMANTREE=C:\Program Files\Pixar\RenderManProServer-23.3
RFHTREE=C:\Program Files\Pixar\RenderManForHoudini-23.3
RMAN_PROCEDURALPATH=$RFHTREE\18.0\openvdb;&
HOUDINI_PATH=“C:/ProgramData/Redshift/Plugins/Houdini/18.0.460;$RFHTREE\18.0;&”
PATH=$RMANTREE\bin;&
At a glance, your quote characters are are wrong and on some lines they are missing.
For you final $PATH variable, don't forget to add in the previous $PATH.
Something like this..?
PATH = "C:/ProgramData/Redshift/bin;$PATH"
HOUDINI_PATH = "C:/ProgramData/Redshift/Plugins/Houdini/18.0.287;@/python2.7libs;&"
HOUDINI_DEFAULT_RIB_RENDERER=prman23.3
RMANTREE="C:\Program Files\Pixar\RenderManProServer-23.3"
RFHTREE="C:\Program Files\Pixar\RenderManForHoudini-23.3"
HOUDINI_PATH=$RFHTREE\18.0;$HOUDINI_PATH;&
PATH=$PATH;$RMANTREE\bin;&
