@instance attribute with Mantra
Hi
With Redshift to render instanced object from point, I sometime simply use the @instance attribute and it works directly.
But doing this with mantra it just render points. I search in the render tab of the object and in the mantra rop but found nothing. I know I can use an instance sop or object.
But I wonder to know where is the option to make points with just @instance attribute, render in mantra.
if you don't want to use Instance Object, you can also just add Point Instancing (ptinstance) render property to your object that outputs points  and switch it from None to one of the other options
also add Instance Object (instancepath), but you can keep that one empty since you have s@instance attribute
you can also add other instancing properties, that Instance Object has by default
  • Thanks 1
