Drughi Posted July 3, 2020 Share Posted July 3, 2020 (edited) Hi, I just wanted to try arnold, but when I try to render it seems to not find "driver_houdini.so" , altough it is in the arnold plugin directory. Can someone tell me how to fix this? I'm on centos8. 00:00:00 103MB WARNING | unable to load dynamic library /root/htoa/htoa-5.3.0_r233605f_houdini-18.0.499/htoa-5.3.0_r233605f_houdini-18.0.499/arnold/drivers/driver_houdini.so: libHoudiniUT.so: cannot open shared object file: No such file or directory 00:00:00 103MB ERROR | [ass] line 26: node "driver_houdini" is not installed 00:00:00 104MB WARNING | rendering with watermarks because the skip_license_check option was enabled 00:00:00 118MB ERROR | [aov] output references a non-driver node: /out/arnold1:iprsocket 00:00:00 118MB ERROR | [aov] output references a non-driver node: /out/arnold1:iprsocket 00:00:00 118MB ERROR | [aov] no valid output statements found: could be a progressive render without a display window 00:00:00 118MB WARNING | failed to launch bucket workers: received abort signal Edited July 3, 2020 by Drughi Quote Link to comment Share on other sites More sharing options...
