HF Scatter Source Point Tag
Hello,
I have a HF and already given points for trees from a LiDAR file.
Instead of using a mask I would like to use the points to use HF scatter.
I plugged the points into the "mask or scatter points" input and in HF scatter I chose "Per point count using source points"
But nothing is scattered.
I dont really get the "tag" field.
Do I have to feed the HF scatter with some attribute?
Thx alot :)
I tried the particle fluid surface SOP again.
Since the HD is very big, it didnt work as expected first - so I scaled the points, used the particle fluid surface again and finaly scaled it back to normal size.
That works. :)
