why does my FEM object intersect itself
Valent
It's little hard to find the problem without looking at the scene and checking FEM parameters, there is few possibilities :
1. crank up substeps in fem solver and also collision passes.
2. check solidobject( model tab) setting in dops, make sure you have some numbers for shape stiffness and volume stiffness.
3. also check collision tab and make sure everything is checked on.
4. Remesh your geometry before converting to solidembed or solidconform.
  • 3 months later...
