gemini Posted July 20, 2020 Share Posted July 20, 2020 (edited) Hi Everyone, Can the the ortho grid be hidden in python ( I sure it can be ) ? ( Not the reference Plane ! ) Thanks in advance ! G Edited July 20, 2020 by gemini Quote Link to comment Share on other sites More sharing options...
ikoon Posted July 20, 2020 Share Posted July 20, 2020 (edited) Hi Szabolcs, I am using this script: for pane in hou.ui.curDesktop().paneTabs() : if pane.type() == hou.paneTabType.SceneViewer : settings = pane.curViewport().settings() settings.setDisplayOrthoGrid(not settings.displayOrthoGrid()) Unfortunately, this change is not immediately reflected in the Perspective viewport. I sent RFE (quoted below), and SideFX logged this in their database; Bug (ID# 100052) Please, if I use this script to toggle the grid in the perspective view, then the change is not reflected immediately. I have to switch to Ortho view and back to Perspective to see the grid updated (toggled on/off) If the same issue happens to you, please RFE it too and mention the Bug ID# I am using version 18.0.353 Edited July 20, 2020 by ikoon Quote Link to comment Share on other sites More sharing options...
