ElemKlimov Posted July 20, 2020 Share Posted July 20, 2020 good day - i have a lopoly set that i plan to use for baking. i have added a boolean to merge the group together. i would now like to select all edges and apply a chamfer/bevel - to soften to 90 deg angle. any suggestions? Quote Link to comment Share on other sites More sharing options...
ElemKlimov Posted July 20, 2020 Author Share Posted July 20, 2020 (edited) ok wait. naturally a bevel sop a couple problems however - although minor. some of the edges/corners are inverted? and in the bevel sop node i get: Warning Skipping nonmanifold edge(s): p439-438 Skipping edge(s) with nonmanifold endpoint(s): p439-393 p1349-1350 p1350-1351 p1355-1350 p1376-1350 p1375-1350 p1029-1350 p4132-438 p439-440 and there appears to be openings. i tried adding the fuse node - but that won't work as i would like to keep my bevels consistent. Edited July 20, 2020 by ElemKlimov Quote Link to comment Share on other sites More sharing options...
eimk Posted July 21, 2020 Share Posted July 21, 2020 If you turn on 'Ignore Flat Edges' in the bevel node and increase the angle you'll get rid of the unnecessary beveled edges and the remaining ones should be cleaner. Increasing divisions to 2 might also help with the corners. If there are still non-manifold edges etc the clean node might be able to fix that. Quote Link to comment Share on other sites More sharing options...
