cloudamy Posted July 29, 2020 Share Posted July 29, 2020 Hi, I have a general question about the workflow of houdini of solver node. I created a volume with a vector field called h, and I tried to update h at each time step using a solver node, and then I tried to print using a python node to see if h got modified, but it is not, it is still the initial value. Can someone explain to me why this is the case? Thanks a lot! Quote Link to comment Share on other sites More sharing options...
bunker Posted July 29, 2020 Share Posted July 29, 2020 (edited) your display flag should be on the volumewrangle and the input of that node should be Prev_Frame OR Input_1 Edited July 29, 2020 by bunker Quote Link to comment Share on other sites More sharing options...
cloudamy Posted July 29, 2020 Author Share Posted July 29, 2020 9 hours ago, bunker said: your display flag should be on the volumewrangle and the input of that node should be Prev_Frame OR Input_1 Ohhhh! Thank you so much! When I put the display flag on the volumewrangle, it somehow says that my vector is a float??? Here I attached a screenshot of my volume h and the error message If possible, can you also explain to me what's the relationship between prev_frame and input_1 or guide me to where I can learn about it myself? Quote Link to comment Share on other sites More sharing options...
bunker Posted July 29, 2020 Share Posted July 29, 2020 maybe post a hip file Quote Link to comment Share on other sites More sharing options...
cloudamy Posted July 29, 2020 Author Share Posted July 29, 2020 7 minutes ago, bunker said: maybe post a hip file Here it is! Thank you so much! example.hipnc Quote Link to comment Share on other sites More sharing options...
eimk Posted July 29, 2020 Share Posted July 29, 2020 In the volume wrangle you need to specify that 'h' is a vector by using 'v@h' rather than just '@h'. VEX assumes everything is a float unless told otherwise, or if it is one of a few specific attributes like Cd. This page has some helpful info on attributes in VEX https://www.sidefx.com/docs/houdini/vex/snippets#attributes 1 Quote Link to comment Share on other sites More sharing options...
cloudamy Posted July 30, 2020 Author Share Posted July 30, 2020 1 hour ago, eimk said: In the volume wrangle you need to specify that 'h' is a vector by using 'v@h' rather than just '@h'. VEX assumes everything is a float unless told otherwise, or if it is one of a few specific attributes like Cd. This page has some helpful info on attributes in VEX https://www.sidefx.com/docs/houdini/vex/snippets#attributes Oh! Ok, thank you! Quote Link to comment Share on other sites More sharing options...
