lens shader dose not work in redshift
Lens shader dosenot work on redshift .
It works on mantra.
Is there any setting when i use lens shader in redshift ??
Below render is by mantra.It works well.
I just use projection type "lens shader" , and use default asadlens.
below render by redshift.
ASAD lens projection type is polar (same as matra render) type , but result is not correct.
It seems redshift dose not render this lens shader.
I've attached this file.
Thank you.
Q.hiplc
