dandandan Posted August 13, 2020 Share Posted August 13, 2020 Hi, I have a sequence of obj with unconnected points and missing faces, can anyone suggest the best way to restore it in houdini? prova5.obj Quote Link to comment Share on other sites More sharing options...
konstantin magnus Posted August 14, 2020 Share Posted August 14, 2020 Hi Dan, I would first rotate the point cloud based on two points off of a line. Then put a new grid on top and transfer the depth values. If the camera is static you should store the rotation once to avoid flickering. mesh_flat_pc.hipnc 1 Quote Link to comment Share on other sites More sharing options...
dandandan Posted August 18, 2020 Author Share Posted August 18, 2020 Thank you Konstantin, so clever and so nice of you! you got me solved! Quote Link to comment Share on other sites More sharing options...
